Issue with AirPrint vs Aruba IAP setup
  • 1.  Issue with AirPrint vs Aruba IAP setup
    Posted Sep 01, 2017 02:04 AM
    Hello guys!
    We have a customer with a single IAP, and they have now bought a new printer with Airprint.
    We have no way of finding the printer on the debt VLAN.
    VLANs:
    VLAN1: admin, where the AP is untagged on.
    VLAN10: WIFI where printers and clients are on.
    I have tried to disable firewall on the router/firewall (ZyXEL USG 110), and there is no restrictions on the SSID (under security tab).
    I have seen this before in other IAP setups - Have you any experince?
    Best regards
  • 2.  RE: Issue with AirPrint vs Aruba IAP setup
    Posted Sep 01, 2017 06:50 AM
    Is the client on vlan 10?
  • 3.  RE: Issue with AirPrint vs Aruba IAP setup
    Posted Sep 01, 2017 07:55 AM
    Yes, the client is on the VLAN 10 SSID :)
  • 4.  RE: Issue with AirPrint vs Aruba IAP setup
    Posted Sep 01, 2017 08:08 AM
    Make sure broadcast filtering is set to "none" in the SSID under advanced.
  • 5.  RE: Issue with AirPrint vs Aruba IAP setup
    Posted Sep 01, 2017 09:06 AM
    Like "Disable"?
  • 6.  RE: Issue with AirPrint vs Aruba IAP setup
    Posted Sep 21, 2017 04:54 AM
    Seems that fixed the issue. :-) Thanks.
