Issue with VIA in route mode. NAT works fine. Any suggestions?
I have VIA working fine in NAT mode.  When remove source nat from the interface and remove the SRC-NAT rule from the default-via-role I can't get traffic to/from the client machine.
If any of you have this working and wouldn't mind sharing that part of your config, I'd really appreciate it.
Robert
Re: Issue with VIA in route mode. NAT works fine. Any suggestions?
The only way it will work in route mode is if your VPN pool that you put clients into is on a subnet that is currently on the controller.  If your controller has a VLAN that has an ip address like:
192.168.1.1 /24 , you would need to have your VPN pool like this 192.168.1.10 - 192.168.1.50.
When you do that, the clients get a fully routable address that can be reached by your infrastructure, without requiring nat
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
