Frequent Contributor I
Issue with flash graphs not displaying in version 7.5.7
I have recently upgraded to version 7.5.7 in order to resolve some issues with VisualRF. (Which worked well!)... Unfortunately since the upgrade I am not now seeing any data on the flash graphs anywhere in airwave. (Be it client throughput or graphs on the dashboard.).
I've restarted AMP and rebooted the server (CentOS 5.5) to no avail.
Is this a know issue/has anyone else experienced this?
Aruba
Re: Issue with flash graphs not displaying in version 7.5.7
I think it would be a good idea to open up a case with support.  There might be some useful informaiton in /var/log/httpd/error_log.
Moderator
I agree with Dan.  The graphs not showing is typically a symptom of another issue elsewhere in AMP.  You might also check the System -> Status and System -> Performance pages to see if anything is out of the ordinary.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
