show ip interface brief
Interface IP Address / IP Netmask Admin Protocol
vlan 101 192.168.208.2 / 255.255.252.0 up up
vlan 1 172.16.0.254 / 255.255.255.0 down down
vlan 100 10.10.8.2 / 255.255.255.0 up down
loopback unassigned / unassigned up up
mgmt unassigned / unassigned down down
show ip route
Gateway of last resort is Imported from DHCP to network 0.0.0.0 at cost 10
Gateway of last resort is Imported from CELL to network 0.0.0.0 at cost 10
Gateway of last resort is Imported from PPPOE to network 0.0.0.0 at cost 10
Gateway of last resort is 192.168.208.1 to network 0.0.0.0 at cost 1
S* 0.0.0.0/0 [1/0] via 192.168.208.1*
C 192.168.208.0/22 is directly connected, VLAN101
show vlan
VLAN Description Ports AAA Profile
1 Default GE1/7 Pc0-7 N/A
100 VLAN100 GE1/5-6 N/A
101 VLAN101 GE1/0-4 N/A
show trunk
Trunk Port Table
Port Vlans Allowed Vlans Active Native Vlan
show port status
Port Status
Slot-Port PortType adminstate operstate poe Trusted SpanningTree PortMode
1/0 GE Enabled Down Enabled Yes Disabled Access
1/1 GE Enabled Down Enabled Yes Disabled Access
1/2 GE Enabled Down Enabled Yes Disabled Access
1/3 GE Enabled Down Enabled Yes Disabled Access
1/4 GE Enabled Up N/A Yes Forwarding Access
1/5 GE Enabled Down N/A Yes Disabled Access
1/6 GE Enabled Down N/A Yes Disabled Access
1/7 GE Enabled Down N/A Yes Disabled Access
show interface gigabitethernet 1/5 switchport
Switchport: Enabled
Administrative mode: static access
Operational mode: static access
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: dot1q
Access Mode VLAN: 100 (VLAN0100)
Trunking Native Mode VLAN: 1 (Default)
Trunking Vlans Enabled: NONE
Trunking Vlans Active: NONE
show spanning-tree
Spanning Tree is executing the IEEE compatible Rapid Spanning Tree protocol
Bridge Identifier has priority 32768, address 00:1a:1e:21:be:c0
Configured hello time 2, max age 20, forward delay 15
Current root has priority 32000, address 00:07:50:0c:44:00
Topology change flag is not set , detected flag not set , changes 393
Times: hold 1, topology change 35 hello 2, max age 20, forward delay 15
Timers: hello 0, notification 0
Last topology change: 0 days, 0 hours, 38 mins, 10 secs
Hope that helps and thanks in advance for any clues\
Steve
