Issues connecting windos 10
Hello, is there anyone out there that is experiencing issues connecting windows 10 home basic to the Aruba wireless network????
Re: Issues connecting windos 10
What is the symptoms you see?
Is that a dot1x SSID with termaination enabled on the controller?
What is the firmware version?
Rajaguru Vincent
Rajaguru Vincent
CWNA | CWSP | CWAP | CWDP | ACMP
