Issues setting up Aruba OS 8.3.0.0 Virtual Controller on Hyper-V VM
Looking for some assistance.  Currently trying to set up Aruba OS 8.3.0.0 Virtual Controller on Hyper-V VM and am having no luck reaching the controller once the virtual ports are set to trunks.  I'll admit that I am not very familiar with VMs.  Following the instructions from Aruba, and can't tell if I am missing anything.  Any help would be appreciated.
Thank You.
Super Contributor I
Re: Issues setting up Aruba OS 8.3.0.0 Virtual Controller on Hyper-V VM
Have you tried to Enable MAC adress spoofing and uncheck Protected network for each Network Adapters?
~Trinh Nguyen~
Boys Town
Thank You.
Have you seen the Virtual Appliance Installation Guide here?  https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Default.aspx?EntryId=29620
