Issues upgrading from to
We have experienced serious degradation in browsing after upgrading to and was wondering if anyone else has experienced similar issues.  We are running two 3600 in a master and standby configuration, the guest networks are throttled to 512Kbps up and down.  When running on speed test sites we get consistent speeds of 680Kbps down and 670Kbps up.  After upgrading (both controllers) we get varied speeds of between 300Kbps to 50Kbps down and 200Kbps and 100Kbps up.  This isn't the first time we have had an issue with upgrading to 6.1.3 (we had similar issues when trying to upgrade in march).  I've logged a call with our support asking this to be raised with TAC but I was wondering if anyone out there had any ideas or has had similar issues ?
Thanks in advance
This has gone through TAC and is confirmed as a bug #66798
