Contributor I
Janam XM-66 Hand scanner
Hello everyone-
I have a department here on campus that is looking to use the Janam XM-66 hand scanner on wireless.  I've read the Aruba technology solution guide on it (https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&cad=rja&uact=8&ved=0CEMQFjAC&url=http%3A%2F%2Fwww.arubanetworks.com%2Fpdf%2Fpartners%2FPSB_JanamXM66.pdf&ei=tUYQVIGuBYmryATNhYKYBg&usg=AFQjCNE4Rwc6y1e-FeKaiXnpLdppFjVPdg&sig2=1dGwkWFYiCB... and figured it to be a good device to use.  I am wondering if anyone out there in the community is using this device on 802.1X in the real world?  Any gotchas?
