L2GRE TUNNEL between two HA controller (vrrp)
I was reading and surfering about this topic but some of my doubts are not clear yet.
I have two master controller configured in HA (vrrp - master/standby) on the corp and two master controller configured in HA (vrrp - master/standby) on DMZ, all APs terminate their gre tunnels on corp master so I need confugire a L2GRE tunnel between HA-corp and HA-DMZ.
I was reading a VRD regarding mobile firts, this document uses two local controller thay point to DMZ controller VRRP VIP, this idea is clear, but i the other hand the controller DMZ-VRRP point to individual local controller of the corp network..
my doubts is: when i configure the L2GRE tunnel between two HA master (VRRP) the tunnel must point to VRRP on both HA??  I think the answer is YES, but I would like con double check.
thanks guys!
Re: L2GRE TUNNEL between two HA controller (vrrp)
Yes.  http://community.arubanetworks.com/t5/Wireless-Access/GRE-L2-tunnel-from-Local-to-VRRP-Master/td-p/219331/page/2
