L2TP pool reset
  • 1.  L2TP pool reset
    Posted Mar 06, 2017 05:16 AM
    We have a large L2TP pool (8000 odd address) for our VPN clients, every time a client connects or reconnects another IP is assigned incrementally.
    My question is, what happens once all addresses have been used, does the pool reset? (not all addresses are used simultaneously)
  • 2.  RE: L2TP pool reset
    Posted Mar 06, 2017 05:30 AM
    Try this command to see how many addresses are in use/free.
    #show vpdn l2tp local pool
    When an address is no longer in use it will be released back into the pool.
  • 3.  RE: L2TP pool reset
    Posted Mar 06, 2017 05:33 AM
    Hi James,
    All addresses not in use are free which is good. My concern is, what happens when the last ip in the range is used. Does it then start from the 1st IP again?
    Cheers,
    Jack
  • 4.  RE: L2TP pool reset
    Posted Mar 06, 2017 05:58 AM
    Hi Jack, Yes. The addresses used increment each time. When the last address in the pool is used the 1st available one will be used next.
