Regular Contributor I
L3 controller with Local Captive Portal
I have a controller configured for Layer3 in that it will host the L2/L3 for several networks and use a single uplink and default route to reach the rest of the network.
I am having issues with Guest Redirect if I place the VAP on one of these L3 networks. The Guest gets an IP but never gets redirected to the local Captive Portal (using the controllers captive portal).
If I move the VAP to the VLAN configured for the uplink, it works fine.
Not sure what I am doing wrong.
Trunk interface - Only VLAN 1 allowed
VLAN 1 - 10.10.10.10 (Controllers IP)
IP ROUTE 0.0.0.0 0.0.0.0 10.10.10.1
VLAN 20 - 10.20.20.20
Operstate UP
Return paths are created in the infrastructure. I can ping 10.20.20.20 with no issues. I can  even stand up DHCP in the infrastructure for VLAN 20 and it will offer an IP to the client.
VAP on VLAN 20 - Captive Portal Redirect does not work
CAP on VLAN 1 - Client gets redirected without issue.
Help?
Re: L3 controller with Local Captive Portal
http://community.arubanetworks.com/t5/Controller-Based-WLANs/How-do-I-change-the-captive-portal-redirect-IP-address/ta-p/181410
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
I did every search imaginable on the forumn and did not come across that. Thanks! It did the trick!!
