- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
LACP Between HP and Aruba 3400
09-27-2013 07:51 AM
My core switch is an HP 5400 series
2 x Aruba 3400 Controllers in a master/local config
Aruba OS 6.2.1.3
We are running 85 AP's and average 550 wireless clients. We are starting to see some slow network access at high traffic times. I would like to try setting up 2 links from the controller to the core and see if that helps.
Seems like configuring the Aruba side is fairly straight forward and documented. Is there anyone who has done this with HP and would be willing to share their config on the HP switch side?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
Re: LACP Between HP and Aruba 3400
09-27-2013 08:06 AM
Have not done this with HP switches but all of my controllers are running LACP to our Brocade switches without issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
09-27-2013 08:09 AM
I think that with HP procurve, by default LACP is on every port by default. Currently, i have a couple of stacks that are connected by 4 x gigabit copper connections and have LACP configured. Configuring it to work between 2 similar HP switches is very simple and works very well.
Hopefully someone who's figured it out can save me a lot of headaches :)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
09-27-2013 10:44 AM
This document helped me set it up on the HP Procurve switches.
http://www.hp.com/rnd/support/config_examples/2524_lacp.pdf
If you still have trouble i can pull the configs of the switches and send them to you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
09-27-2013 10:47 AM
I don't have a test aruba controller, but i do have a test cisco switch
Is it safe to assume that if i can make this work between an HP and Cisco switch, that the aruba controller is similar enough to Cisco that the config would be very similar?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
