Occasional Contributor I
LACP Channel between aruba s3548 and cisco 3750
I am having trouble getting an LACP Port channel working between an aruba s3548 and a cisco catalyst 3750 switch.  I am able to get the port channel up, but the trunking does not seem to take effect.  I am only able to access vlan 1.  When the cisco ports come up,  they are amber for 40 seconds leading me to beleive they are coming up in access mode.  Below  are the configs I am using.
--#  Cisco 3750 Config #--
spanning-tree mode pvst
interface Port-channel1
Interface GigabitEthernet 1/0/3
   Description Uplink Port
   switchport mode trunk encapsulation dot1q
   channel-group 1 mode passive
Interface GigabitEthernet 1/0/4
--Interface Status --
status
   Gi1/0/3                      connected    trunk      a-full a-1000 10/100/1000BaseTX SFP
   Gi1/0/4                      connected    trunk      a-full a-1000 10/100/1000BaseTX SFP
   Po1                          notconnect   unassigned   auto   auto
--# Aruba 3548 config #--
spanning-tree
   mode pvst
interface-profile switching-profile "Trunk Port"
   switchport-mode trunk
interface-profile lacp-profile "3750"
   group-id 1
   mode active
   timeout short
interface port-channel "1"
   enet-link-profile pc_default
interface gigabitethernet "1/0/36"
   lacp-profile "3750"
interface gigabitethernet "1/0/37"
   lacp-profile "3750"
Re: LACP Channel between aruba s3548 and cisco 3750
Looks like you are missing the switchport configuration on the port-channel on the Cisco side.
Tim Cappalli | Aruba Security
That was a fast response.  I have tried it with the following (am willing to try again)  it did not seem to make a difference.
interafce portchannel1
   switchport trunk encapsulation dot1q
The interfaces had the same ctrunk commands as well.
Are all of your VLANs defined on both switches?
I can safely say that they are NOT.  I will give this a try and report back.
Sorry got busy and just last night had some time to test this again.  I made sure the same vlans existed on both sides.  I also limited the vlans that were on the trunk,  no luck.   Below are the latest configs I was using.  Same thing,  cisco ports would show a spanning tree negotiation in the form of amber ports for some time,  the link would come up for about 3 seconds then shut down.  I also tried setting the cisco side to a static port channel by using "channel-group 1 mode on"   this did not help.
--= Cisco 3750 config =--
interface FastEthernet1/0/21
 description Uplink to Aruba
 switchport trunk allowed vlan 1,8,10,21,22,23,24
interface FastEthernet1/0/22
--= Aruba s3500 Config =--
 spanning-tree
   mode pvst
   trunk allowed vlan 1,8,10,21-24
   group-id 1
   mode active
interface gigabitethernet "1/0/34"
   lacp-profile "3750"
interface gigabitethernet "1/0/35"
   lacp-profile "3750"
Aruba
dymes,
I didn't notice it before in your config but your 3750 only has FastEthernet ports right. I think the issue is a Layer 1 configuration mismatch. This is the Layer 1 setting for port-channels by default:
(host) # show interface-profile enet-link-profile pc_default
Ethernet Link "pc_default" (Predefined (changed))
Parameter        Value
Speed            1000
Duplex           full
Autonegotiation  Enabled
Flowcontrol      off
So it means that we're trying to bring the link up at GE speed. Make the following change:
interface-profile enet-link-profile "pc_default"
   speed 100
   duplex full
Best regards,
Madani
Thank you all,  This is now working (in my lab at least,  Need to do some production stuff)  Below are my final configs.
--== Cisco 3750 ==--
spanning-tree extend system-id
lldp run
interface FastEthernet1/0/45
 switchport trunk allowed vlan 1-3
 channel-group 1 mode active
interface FastEthernet1/0/46
interface FastEthernet1/0/47
interface FastEthernet1/0/48
--== Aruba s3500 ==--
interface-profile poe-profile "uplink"
interface-profile enet-link-profile "3750-enet"
   speed 100
   duplex full
   group-id 1
   mode active
   timeout short
interface-profile lldp-profile "uplink"
   lldp transmit
   lldp receive
spanning-tree
   mode pvst
vlan "1"
   description "LAN Access"
vlan "2"
   description "Accounting"
vlan "3"
   description "Wireless"
interface gigabitethernet "0/0/44"
   lacp-profile "3750"
interface gigabitethernet "0/0/45"
   lacp-profile "3750"
interface gigabitethernet "0/0/46"
   lacp-profile "3750"
interface gigabitethernet "0/0/47"
   lacp-profile "3750"
