LACP don't work after reload
Hello everybody,
I have a doubt with port channel configuration on AOS 6.1.3.5
interface gigabitethernet  1/2
        description "GE1/2"
        trusted
        trusted vlan 1-4094
        lacp timeout short
        lacp group 2 mode active
interface gigabitethernet  1/3
        description "GE1/3"
        trusted
        trusted vlan 1-4094
        lacp timeout short
interface port-channel 2
        trusted
        trusted vlan 1-4094
        switchport mode trunk
        switchport trunk native vlan 20
        switchport trunk allowed vlan 22-23,25,37-39
It shows that both ports are UP:
(AOS1) #show lacp 2 internal
Flags: S - Device is requesting slow LACPDUs
       F - Device is requesting fast LACPDUs
       A - Device is in Active mode P - Device is in Passive mode
LACP Internal Table
Port    Flags  Pri  AdminKey  OperKey  State  Num  Status
GE 1/2  FA     255  0x3       0x3      0x3f   0x3  up
GE 1/3  FA     255  0x3       0x3      0x3f   0x4  up
But after reload they are DOWN.
Other side of the trunk is correct configured: the native vlan is 20 and vlans 22-23,25,37-39 are 802.1q.
MVP
Re: LACP don't work after reload
try including the vlan 20 on the trunk allowed vlans..
For example...
interface port-channel 5
trusted
trusted vlan 1-4094
switchport trunk allowed vlan 1,21-23
Obiusly here the native vlan is 1
On normal trunks taht im not allowing ALL the vlans... if i dont include the native vlan to the switchport trunk allowed vlan it does not work...
Try in your case putting that native vlan on the trunk
In your case
        trusted
        trusted vlan 1-4094
        switchport trunk allowed vlan 20,22-23,25,37-39
Alternetworks Corp
Thank you for solution
It works only with native vlan 1 on both sides.
With native vlan 20 under allowed vlans both LACP ports were DOWN after reload and don't worked
MVP
That does not make sense... ill try doing a lab this weekend.. i wanna see that with my own eyes...
Will come back to you with the results
Cheers
Carlos
Alternetworks Corp
MVP
[ Edited ]
Hello again
Here are my results.. it works pretty good here
With an alcatel Switch...
Here is the results
Before Reloading
        add fastethernet 1/0
        add fastethernet 1/1
        trusted
        trusted vlan 1-4094
        switchport trunk native vlan 10
        switchport trunk allowed vlan 10,20,200
(Office_Alternetworks) #show interface port-channel 5
Port-Channel 5 is administratively up
Hardware is Port-Channel, address is 00:00:00:00:00:00 (bia 00:0B:86:63:33:F6)
Description: Link Aggregate
Spanning Tree is disabled
Switchport priority: 0
Member port:
    FE 1/0, Admin is up, line protocol is up
    FE 1/1, Admin is up, line protocol is up
Last clearing of "show interface" counters 4 day 22 hr 14 min 57 sec
link status last changed 0 day 0 hr 0 min 5 sec
    63 packets input, 8100 bytes
    Received 21 broadcasts, 0 runts, 0 giants, 0 throttles
    0 input error bytes, 0 CRC, 0 frame
    14 multicast, 42 unicast
    48 packets output, 20634 bytes
    0 output errors bytes, 0 deferred
    0 collisions, 0 late collisions, 0 throttles
Port-Channel 5 is TRUSTED
After Rebooting the controller
Member port:
Last clearing of "show interface" counters 0 day 0 hr 4 min 30 sec
link status last changed 0 day 0 hr 1 min 35 sec
    1772 packets input, 244369 bytes
    Received 1038 broadcasts, 0 runts, 0 giants, 0 throttles
    554 multicast, 734 unicast
    743 packets output, 161575 bytes
(Office_Alternetworks) #show version
ArubaOS (MODEL: Aruba620), Version 6.1.3.5
Website: http://www.arubanetworks.com
Copyright (c) 2002-2012, Aruba Networks, Inc.
Compiled on 2012-09-28 at 07:46:05 PDT (build 35523) by p4build
ROM: System Bootstrap, Version CPBoot 1.0.0.0 (build 23274)
Built: 2010-01-19 11:11:41
Built by: p4build@re_client_23274
Switch uptime is 4 minutes 47 seconds
Reboot Cause: User reboot.
Supervisor Card
Processor XLS 204 (revision A1) with 890M bytes of memory.
32K bytes of non-volatile configuration memory.
256M bytes of Supervisor Card System flash (model=NAND 256MB).
On the switch
Alternetworks_6450_Office-> show linkagg
Number  Aggregate  SNMP Id   Size Admin State  Oper State     Att/Sel Ports
   5     Static    40000005   2   ENABLED      UP              2   2
Alternetworks_6450_Office-> show configuration snapshot linkagg
! Link Aggregate :
static linkagg 5 size 2 admin state enable
static agg 1/4 agg num 5
static agg 1/5 agg num 5
Alternetworks_6450_Office-> show system
System:
  Description:  Alcatel-Lucent 6450L 10 PORT COPPER FE POE 6.6.3.413.R01 Service Release, August 16, 2012.,
  Object ID:    1.3.6.1.4.1.6486.800.1.1.2.1.12.1.4,
  Up Time:      9 days 3 hours 29 minutes and 18 seconds,
  Contact:      Alcatel-Lucent, http://alcatel-lucent.com/wps/portal/enterprise,
  Services:     72,
  Date & Time:  SUN DEC 02 2012  16:00:58 (EST)
Flash Space:
    Primary CMM:
      Available (bytes):  64409600,
      Comments         :  None
IF i reboot the switch not the controller
System:
  Up Time:      0 days 0 hours 3 minutes and 26 seconds,
  Services:     72,
  Date & Time:  SUN DEC 02 2012  16:05:34 (EST)
Flash Space:
    Primary CMM:
      Comments         :  None
 As you see in the results everything worked fine...I noticed that you configured lacp to have control over the port channel
        lacp timeout short
Do it without that... let the port channel have the control of it... and it should work... anyways check my config...
Leave the ports that you are aggregating to the link aggregation with no config of lacp....
interface fastethernet 1/0
        description "FE1/0"
        trusted
        trusted vlan 1-4094
        switchport access vlan 1000
interface fastethernet 1/1
        description "FE1/1"
        trusted
        trusted vlan 1-4094
 here is what i got on the ports... which is not being used... as the port channel is taking over the LACP
Alternetworks Corp
Thank you for your response.
I've also an alcatel config on the other side, but with dynamic LACP.
It is a good clue - I will try without these lines:
lacp timeout short
Question to your config:
Need I realy the access vlan in interface configuration if I configure port-channel?
        description "FE1/0"
        trusted
        trusted vlan 1-4094
Tested without
lacp timeout short
and it works like a charm.
It seemed that the active LACP functions properly only with the native vlan 1.
Passive mode and lacp timeout long works also with other trusted native vlan.
MVP
Nice to know that!
Mark it as solution also so other with the same problem knows wihtout reading everything!
Alternetworks Corp
Frequent Contributor II
How can I debug?
I have troubles in switches side ("Aruba config is OK, nothing more to do")..
What about: http://community.arubanetworks.com/t5/tkb/articleprintpage/tkb-id/ControllerBasedWLANs/article-id/2039
I have this in our LAB:
vlan 1003
spanning-tree mode rapid-pvst
no spanning-tree
interface gigabitethernet 0/0/0   (Just to Power UP ;) )
        description "GE0/0/0"
        trusted
        trusted vlan 1-4094
interface gigabitethernet 0/0/1
        description "GE0/0/1"
        trusted
        trusted vlan 1003
        switchport trunk native vlan 1003
        switchport trunk allowed vlan 1003
        lacp timeout short
        lacp group 1 mode active
        lldp transmit
        lldp receive
interface gigabitethernet 0/0/2
        description "GE0/0/2"
        trusted
        trusted vlan 1003
        lacp timeout short
        lldp transmit
        lldp receive
interface gigabitethernet 0/0/3  (to test and config in GUI with a laptop :P )
        description "GE0/0/3"
        trusted
        trusted vlan 1003
        switchport access vlan 1003
interface port-channel 1
        trusted
        trusted vlan 1-4094
        jumbo
        no spanning-tree
        no spanning-tree point-to-point
interface vlan 1003
        ip address 10.10.3.150 255.255.252.0
ip default-gateway 10.10.3.250
no uplink wired vlan 1
uplink disable
ip nexthop-list pan-gp-ipsec-map-list
ip igmp
ipv6 mld
firewall attack-rate grat-arp 50 drop
firewall jumbo mtu 9216
ipv6 firewall ext-hdr-parse-len  100
logging level debugging network process fpapps
logging level debugging network process lldp
logging level debugging network process hwmon
logging level warnings security subcat ids
logging level warnings security subcat ids-ap
logging level debugging system process fpapps
I update OS after LACP fails:
(master) #show port stat
Port Status
Slot-Port  PortType  AdminState  OperState  PoE  Trusted  PortMode  Speed   Duplex
0/0/0      GE        Enabled     Down       N/A  Yes      Access    Auto    Auto
0/0/1      GE        Enabled     Up         N/A  N/A      PC1       1 Gbps  Full
0/0/2      GE        Enabled     Up         N/A  N/A      PC1       1 Gbps  Full
0/0/3      GE        Enabled     Down       N/A  Yes      Trunk     Auto    Auto
PC1        PC        Enabled     Down       N/A  Yes      Trunk     N/A     N/A
(master) #
(master) #show log all  20
May 25 01:52:08  cfgm[3521]: <307219> <DBUG> |cfgm| Sending the IPSEC Configuration
May 25 01:52:10  lldp[3987]: <235003> <DBUG> |lldp|  LLDP Sent PKT at egress 8449
May 25 01:52:11  lldp[3987]: <235003> <DBUG> |lldp|  LLDP Sent PKT at egress 8450
May 25 01:52:12  fpapps[3560]: <208801> <DBUG> |fpapps|  LACP: dot3adPduTx: intIfNum 2 rc 0
May 25 01:52:12  fpapps[3560]: <208801> <DBUG> |fpapps|  LACP: dot3adPerMach: intf 2 event 12 curState 3 nextState 2
May 25 01:52:12  fpapps[3560]: <208801> <DBUG> |fpapps|  LACP: dot3adPerMach: intf 2 event 14 curState 2 nextState 3
May 25 01:52:13  fpapps[3560]: <208801> <DBUG> |fpapps|  LACP: dot3adPduTx: intIfNum 3 rc 0
May 25 01:52:13  fpapps[3560]: <208801> <DBUG> |fpapps|  LACP: dot3adPerMach: intf 3 event 12 curState 3 nextState 2
May 25 01:52:13  fpapps[3560]: <208801> <DBUG> |fpapps|  LACP: dot3adPerMach: intf 3 event 14 curState 2 nextState 3
May 25 01:52:23  cfgm[3521]: <307048> <DBUG> |cfgm|  Got a message from 8231:5010
May 25 01:52:23  cfgm[3521]: <307050> <DBUG> |cfgm| Received a IPSEC CFG Message
May 25 01:52:23  cfgm[3521]: <307219> <DBUG> |cfgm| Sending the IPSEC Configuration
May 25 01:52:25  cfgm[3521]: <307026> <DBUG> |cfgm|  master: Refreshing the lms list
May 25 01:52:25  cfgm[3521]: <307027> <DBUG> |cfgm|  Checking the LMS not responding flag for local 10.10.3.150 flag value is 1, missedHB 0 socketID -1
May 25 01:52:25  stm[3669]: <337000> <DBUG> |stm|  mon_mgr_update_thread_main: updateq empty. into conditional wait...
May 25 01:52:25  ucm[4143]: <337000> <DBUG> |ucm|  mon_mgr_update_thread_main: updateq empty. into conditional wait...
May 25 01:52:26  fpapps[3560]: <399814> <DBUG> |fpapps|  aruba_xlp_check_dtr: channel 0 recv 0x14e6 sent 0x14e6 diff 0x0
May 25 01:52:26  fpapps[3560]: <399814> <DBUG> |fpapps|  aruba_xlp_check_dtr: channel 1 recv 0x2e781 sent 0x2e781 diff 0x0
May 25 01:52:26  fpapps[3560]: <399814> <DBUG> |fpapps|  aruba_xlp_check_dtr: channel 2 recv 0x0 sent 0x0 diff 0x0
May 25 01:52:26  fpapps[3560]: <399814> <DBUG> |fpapps|  aruba_xlp_check_dtr: channel 3 recv 0x0 sent 0x0 diff 0x0
(master) #
P.D.: To one switch LACP works, to diferent switches (that i want) dont: btw: http://community.arubanetworks.com/t5/Wireless-Access/Link-Aggregation-LACP-on-Aruba-Controller-Jan06-Tutorial/m-p/267355#M60746 .
Best regards.
