LAG in AP-335?
Hi Folks,
I am configuring LAG in Aruba AP-335 and wanted to know the behavior of traffic flow and load balancing in LAG. I am using Cisco switch 3850 and created LACP port-channel on the switch. I read the Aruba documents regarding configuring LACP on access points and  configured according to it on Aruba controller. The LMS IP is the IP of the controller 192.168.5.100 and GRE Striping IP is 192.168.5.101. I confirmed the LACP is working fine by checking the LACP ap status on the controller as well as on switch. I have tested both 2.4GHz and 5GHz bands.
I am seeing the Tx bytes flow on Cisco switch secondary port which is connected to Eth1 of AP and Rx is on the primary port which connected to ETH 0 of the AP. There is no load balancing of Tx and Rx bytes on both ports.  Is that an expected flow of traffic ?
Regular Contributor II
Re: LAG in AP-335?
Has anyone deployed LACP on AP-335? People are buying these AP for m-gig and LACP capabilities not awar that if you LAG eth0 and eth1 you only get 2 gb throughput and not the m-gig + eth1 1gig. Can some one verify please??
I'm not talking GRE stripping. just good old port bonding.
Occasional Contributor I
Re: LAG in AP-335?
Hi there.
I see similar usage on my own setup. It would be good to know if this is by design or not. I have found no documentation that says one way or another.
5 Ghz load shares correctly on Rx.
5 Ghz on Tx doesn’t seem to load share at all (16 packets).
2.4GHz doesn't load share at all.
  (xxxxxxx) #show ap debug lacp ap-name a8:bd:27:c5:xx:xx
AP LACP GRE Striping IP: 10.205.1.19
AP LACP Status
Link Status  LACP Rate  Num Ports  Actor Key  Partner Key  Partner MAC
Up           slow       2          17         1            e8:b6:c2:62:1d:cb
Slave Interface Status
Slave I/f Name  Permanent MAC Addr  Link Status  Member of LAG  Link Fail Count
eth0            a8:bd:27:c5:0b:2e   Up           Yes            0
eth1            a8:bd:27:c5:0b:2f   Up           Yes            1
GRE Traffic Received on Enet Ports
Radio Num  Enet 0 Rx Count  Enet 1 Rx Count
0          322385           322383
1          535              0
non-wifi   668              658
Traffic Sent on Enet Ports
Radio Num  Enet 0 Tx Count  Enet 1 Tx Count
0          732282           16
1          149              0
non-wifi   697              1187
