Contributor I
LAN-Printers not visible on OS X devices
Hi there,
OS X devices cannot search for printers (HP) when they are connected via WiFi. Some do appear once some never. Cannot find any systematic issue in that.
We have an 7005 and a group of five AP315 with a company wide WLAN in "Tunnel mode". No Airwave.
What is missing?
Thanks - F.One
Re: LAN-Printers not visible on OS X devices
How does the OS X devices discover the printers? Is it via AirPrint? Have you got any AirGroup options configured? What are the ACL's assigned to the OS X devices, do they permit any traffic? Is your VAP set to drop any kind of broadcast traffic? If you can provide some further information on your topology, this would helpful.
ACMA, ACMP, ACSA
If my post addresses your query, give kudos:)
Frequent Contributor I
Are they in the same VLAN? the airprint feature only works when they are inside the same  VLAN, if not you will need to enable Multicast on VLANs which is not recommended IMO
Contributor I
Yes, there is only one VLAN at all.
Can you even ping the printers from the OS X devices?
ACMA, ACMP, ACSA
Contributor I
Yes, I can ping them and can print to them via IP instead of Bonjour - but I am the admin and do know that - 99% percent of users have no idea why no or just a few printers do appear.
Contributor I
Hi, no, it is not airprint. OSX does search for network printer via Bonjour (UPnP)
No Airgroups, no special ACLs.
I did not configure special rules to drop broadcasts - if it is a default behavior - where should I allow this?
The topology is as easy as one can imagine:
5 AP315 connected to a HP 5400zl with PoE - 1 aruba 7005 controller with a trunk of 4 Gbps connected to the same 5400zl.
And the printers, too. Some via an uplink switch to the upper floor but one collision domain (192.168.0.0/23) - no special VLAN tagging in this scenario (VLAN is tagged for DMZ only).
Contributor I
No idea anyone?
It is the "default via role" with policy "allow all".
No limits are set, no airgroups configured.
It is reproduceable: connecting a macbook via LAN will immediately show all printers anouncing them by bonjour.
Switching back to WLAN will make them invisible after a while.
I would disable Airgroup and make sure that there is no broadcast filtering on that Virtual AP.  That would ensure the controller is not blocking any broadcast traffic.
Colin Joseph
Aruba Customer Engineering
Contributor I
Hi Colin,
there is no "Airgroup" at all (and to be honest: I don´t even know where I should configure an airgroup resp. don´t know what this feature is)
There is a menu entry in "dashboard" called "Airgroup" and there is nothing inside than an empty diagram.
