LED's flashing amber
I have a test lab and 3 AP's connected to a single controller. All three AP's have their 802.11 LED's continuously flashing amber. The AP's do not show as active on the controller when I check from the CLI. So it appears I have a communications problem. Do the LED's tell me anything or just that they cannot find their master?
Re: LED's flashing amber
Is there another controller in the network?  If there is, then would these APs be in there?  Is the AP rebooting?  If not, then it did find a controller to join to.
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
The controller and AP's are in a self contained network with nothing else (besides the switch connecting them). They are not rebooting, but they do not appear to have found the controller. Next step is to do a purge.
