LMS Discovery - "Using Saved LMS 192.168.X.X as master directly"
I believe I understand from previous discussions that the only two variables saved on the AP's memory is the "AP-GROUP" AND "AP-NAME" - but not the LMS? While debugging APs in the past, I noticed via the console log a specific log message "Using saved lms 192.168.XX.XX as the master directly" - does this occur only when a static lms address has been applied to an AP?
