Contributor I
LMS
I'm trying to fail over some access points to the primary controller.  As I understand it, you're supposed to go to AP configuration and change the LMS ip.  I have the primary ip and the secondary ip configured correctly and I reset, but the access points are not all going to the primary ip.  Some are going to the primary and some to the secondard switch ip.  Can someone help me out?  Thanks.
Re: LMS
Have you confirm that those APS are able to reach the controller ? Or there’s no big traffic delay in the path
Check the amount of licenses too
Thank you
Victor Fabian
Pardon typos sent from Mobile
Thank you
Victor Fabian
Lead Mobility Architect @WEI
mkk
Contributor II
Re: LMS
What is the version of your mobilitycontroller 8.x or early?
Contributor I
Re: LMS
It's early. 6.4.4.10. But, I went to provision, didn't make any changes, and just "applied and reset" the offending Access Points and they are coming up on the correct controller now. So, looks like it's fixed.
Ken
Contributor I
Re: LMS
일부 ap만 변경 하려면 ap의 그룹 나누어 설정 해야합니다.기본적으로 lms-backuplms 하고 일부 ap만 별도의 그룹으로 지정하여 lms-backuplms ip를 반대로 설정 하게 되면 서로 다른 그룹이 각각 컨트롤러에 연동 되게 됩니다. 이 설정은 각 ap-group ap system profile 설정에 각각 입력 되야 합니다.
Contributor I
Re: LMS
so an easier way to do this for future if you can in your environment create a vip(vrrp) on each controller. Make the vip the LMS primary and secondary. This just go to the controller and shut the vip of and ap reboots comes up.
Contributor I
Re: LMS
Thanks for that suggestion, but they are not connected by layer 2.
