Latency issue with laptops g clients and ipads
  • 1.  Latency issue with laptops g clients and ipads
    Posted Mar 07, 2014 07:43 AM
    Hi ,
    I am facing latency issue with ipad. We are running internal applications on ipad where it has to communicate with server in cloud.
    In test enviroment we are using Cisco Stand alone access points. We are able to get response from server in 4 secs.
    In production enviroment we are using aruba 105 (controller 7220 code:6.2.14). we are getting response from server in 14-16 secs. So its almost not usable because of delay.
    I tried dropping broadcast and multicast traffic on ssid profile. Now i am getting response in 8-10 secs.I placed device near to ap with clear LOS.I have observed ping drops and more latency checking with laptops connected to same ssid but not with Cisco stand alone access point.even i tried enabling bc/mc optimization. But no use.
    we are doing dot1x with aruba and wpa-psk with Cisco.
    What could be cause for this...???
    srikanth
    #7220
  • 2.  RE: Latency issue with laptops g clients and ipads
    Posted Mar 07, 2014 07:52 AM
    You should start by looking at your rf environment :
    Show ap arm history ap-name
    Show ap arm rf-summary ap-name
    Then if everything looks good make sure that there's layer1 issues between the AP to the controller :
    Show ap debug counters
    Confirm that there's no layer 1 issues from your controller to upstream
    From controller
    Show port stats
    And take a look at your upstream device as well
    You should consider turning on cenable bmcm optimization on that VLAN
  • 3.  RE: Latency issue with laptops g clients and ipads
    Posted Mar 07, 2014 08:23 AM
    From controller
    Show port stats
    Actually there are no layer 1 issues. I have  checkd the port stats and there are no errors. and yes we have many containments and interferring devices. But i checked with AP which has no interference
  • 4.  RE: Latency issue with laptops g clients and ipads
    Posted Mar 07, 2014 07:55 AM
    Do you have airtime fairness enabled?
  • 5.  RE: Latency issue with laptops g clients and ipads
    Posted Mar 07, 2014 08:21 AM
    In Qos, i didnt allocate any VAP.  but station shaping polict is preferred access
