Latest Firmware AP compatibility
I have a 7200 controller with the following AP models deployed,
AP-134
AP-135
AP-224
AP-225
AP-274
How can I determine what the latest compatible OS release is for these AP's? Or is it only determined by the controller's OS compatibility? Is there a document that indicates this?
Re: Latest Firmware AP compatibility
This should help:
http://www.arubanetworks.com/support-services/end-of-life/
Cheers
James
That is exactly what I was looking for. Thanks James.
