Latest firmware for Aruba7030
what is the latest firmware for the Aruba7030 and where can i download it?
thanks for your help
Re: Latest firmware for Aruba7030
support.arubanetworks.com
8.1.0.1 is the latest version 8.
6.5.3.0 is the latest version 6.
Cheers
James
MVP
the latest will be AOS8, but probably you are talking about 6.5.3.X
You can get it from support.arubanetworks.com with your partner login. Otherwise, ask your partner to download it for you.
cheers
Borja
ACMX #567 //ACCP//CWNA//CWAP
You need an active support contract to be able to download ArubaOS upgrades (support.arubanetworks.com).  You can request a login for the support site here:  https://support.arubanetworks.com/Default.aspx?TabId=55
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
