Frequent Contributor I
Latest firmware for IAP-115 APs?
How do I get the latest available stable firmware for the IAP-115? If I check for updates in the IAP maintenance interface, it says it is on the latest firmware (6.4.4.8-4.2.4.6_58505). I however keep seeing references in IAP threads for 6.5.x and some people mentioning higher versions of firmware. The firmware downloads section links to some discussions for firmware that are from 2015.
Re: Latest firmware for IAP-115 APs?
Please try here..http://support.arubanetworks.com/LifetimeWarrantySoftware/tabid/121/DMXModule/661/EntryId/20374/Default.aspx
