Occasional Contributor I
Licence and max AP on 3200
Dear All,
I'm a bit confused here...
According to the datasheet, my 3200 controller can support a max of 32 campus APs, or 128 remote APs.
My show licence-usage looks like this:
(Aruba3200) #show license-usage ap
Total AP Licenses			: 128
Remote-Node AP Licenses Used		: 0
AP Licenses Used			: 21
Tunneled Node Licenses Used			: 0
Unused AP Licenses			: 107
Licenses used for Campus AP's		: 21
Available Campus AP's			: 0
Licenses used for Remote AP's		: 0
Available Remote AP's			: 0
Total Ortronics AP Licenses		: 0
Ortronics AP Licenses Used		: 0
Total Indoor Mesh AP's Supported 	: 128
Indoor Mesh AP's Active			: 0
Total Outdoor Mesh AP's supported	: 128
Outdoor Mesh AP's Active		: 0
 Now, how do I know from this, that my max is 32? I don't plan to deploy remote APs.
Thanks!
Tamas
Re: Licence and max AP on 3200
Use "show keys" to see how many APs you are licensed for.
Okay, and how many campus APs does this mean? :)
(Aruba3200) #show keys
Licensed Features
Feature                                             Status
Access Points                                       128
Remote Access Points                                128
Ortronics Access Points                             0
Outdoor Mesh Access Points                          128
RF Protect                                          22
Voice Service Module                                Unlimited
VPN Server Module                                   2048
xSec Module                                         0
Indoor Mesh Access Points                           128
120abg Upgrade                                      0
121abg Upgrade                                      0
124abg Upgrade                                      0
125abg Upgrade                                      0
Next Generation Policy Enforcement Firewall Module  22
Advanced Cryptography                               0
Service provider AP                                 0
Thanks!
Tamas
Retired Employee
Tamas,
Your AP count is limited to 22 because of the PEF-NG license count of 22. In order to add more campus APs to the controller, you would need to add 10 PEFNG license
Here is my 3200 controller which brings up one AP but another AP shows up with "IL" flag since I have only 1 PEF-NG license.
(master) #show license-usage ap
AP Licenses Used : 1
Unused AP Licenses : 127
Licenses used for Campus AP's : 1
Total PEF Licenses : 1
Remote-Node PEF Licenses Used : 0
PEF Licenses Used : 1
(master) #show keys
Licensed Features
Feature Status
Access Points 128
RF Protect 0
xSec Module 0
120abg Upgrade 0
121abg Upgrade 0
124abg Upgrade 0
125abg Upgrade 0
Next Generation Policy Enforcement Firewall Module 1
(master) #show ap database
AP Database
Name Group AP Type IP Address Status Flags Switch IP
ap105 local1 105 10.163.205.102 Up 6m:42s 10.163.204.42
ap135 local1 135 10.163.205.100 Up 6m:19s IL 10.163.204.42
show log system 10
May 22 12:22:01 :305038:  <WARN> |stm|  No available license for AP ap135
License Table
Key Installed Expires Flags Service Type
Access Points: 128
Next Generation Policy Enforcement Firewall Module: 1
Hope it helps !
HT
HT
The term "campus access point" confuses me.  What is a campus access point?   I am trying to figure out if this is the controller I need for 200 AP's.   Can it  only take 32?
Campus AP means it is not a Remote AP (on older code)
Tim Cappalli | Aruba Security
Yes, the 3200 can only support 32 Campus APs (CAPs). A CAP is an access point that is connected over a LAN and doesn?t encrypt data between the AP and the controller (usually). A Remote AP (RAP) is usually connected over an untrusted network, such as the Internet, and encrypts all data between the AP and controller.
If you need 200 CAPs, you will need a 7210 (up to 512 CAP support).
