Contributor I
Licenses?
Can someone let me know what each aruba licenses are used for or point me in the right direction? Specifically curious on what PEFNG and RFP do, also heard RFP might be going away so we don't need to purchase it.
Re: Licenses?
PEF is policy enforcement firewall which provides role-based access, bandwidth contracts, per-application bandwidth control, application QoS and access control, and firewall policies.
http://www.slideshare.net/ArubaNetworks/getting-the-most-out-of-the-aruba-policy-enforcement-firewall
RFProtect is the WIDS/WIPS module which provides advanced intrustion detection and prevetion and also spectrum monitoring capability.
http://www.arubanetworks.com/products/security/wireless-intrusion-protection/
Tim Cappalli | Aruba Security
Re: Licenses?
Please see here:  http://www.arubanetworks.com/techdocs/ArubaOS_64x_WebHelp/Web_Help_Index.htm#ArubaFrameStyles/New_Licenses/Licenses.htm%3FTocPath%3DLicences%7C_____2
I have not heard anything about RFP going away.  You should check your official Aruba representative or partner.
Colin Joseph
Aruba Customer Engineering
Re: Licenses?
RFP is definatley not going away, as we're both a) still doing feature development, and b) it's required for high security and government wireless deployments.
Jerrod Howard
