Frequent Contributor I
Limit number of UE's per Standalone AP
Hello Dears,
Is it possible to limit the number of associated UE's per a standalone AP? Meaning not connected to a controller, and no AirWave installed..
Reason is we want to limit them to 60 ~ 80 UE's per Outdoor AP, and the controller & AirWave will be installed later on.
The used AP is the outdoor AP-270, (Not the instant model).
Thanks.
Re: Limit number of UE's per Standalone AP
What is a UE?
Tim Cappalli | Aruba Security
Regular Contributor I
I think he means UserEndpoint. But how to install a AP-27x (no instant) as standalone AP? Not possible as far as I see it.
Perhaps use the IAP version and then limit the user amount per SSID.
Cheers, Frank
Aruba Partner Ambassador| AMFX#22| ACCX#613| ACMX#733| ACDX#744
If you like my posts, kudo's are welcome. If it solves your problem, please click 'Accept as Solution'
For OP, a controller is required before deploying any (non-IAP) AP-270s. At which point you can then set a limit on the number of users per radio.
Jerrod Howard
Hello Cappalli,
UE is User Equipment = Subscriber associated to an AP
Thanks jhoward, I have some queries please:
Do you mean the controller here for (non-IAP) is mandatory to operate? Or this is to be able to limit number of users per Radio?
The wanted scenario is:
> 1-3 Mesh Clustered Outdoor (non-IAP) AP's will connect with EoGRE to a WiFi Mobility Gateway, as follows (Mesh AP's <(EoGRE)> TWG <> GW Router <> Firewall <> Internet)
> This is only for Pilot Phase, but final one will have a Controller installed.
> Limit the number of users per AP to ~ 60 for 2.4GHz (5 GHz will be used for backhauling).
Thanks.
Yes. You need a controller for them to operate.
I need more clarification for separate points:
> As per my understanding they can operate with (non-IAP) and without controller, if no limitation is required for number of subscribers.
> But to limit number of users, this will require Instant AP or a controller.
Thanks.
No, if it's a regular AP (non-Instant), you need a controller.
You can limit the number of associated clients on both Instant and controller.
