Occasional Contributor I
Link between authenticated guests and a Firewall NAT pool
Is there a way to match an authenticated WiFi guest with a NAT(PAT) entry of a Firewall? As a provider of public WiFi, I need to answer to the Data Retention directives.
What I need to know is:
- Who was surfing?
- When was he surfing?
- What was he doing on the net?
and that all stored for 1jear.
I know there is a possibility to configure something like this on clearpass and Fortigate. Are there other Firewalls (eg Cisco ASA, ...) that support this also?
Re: Link between authenticated guests and a Firewall NAT pool
EDIT:  Nevermind.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
From ClearPass, we can update Palo Alto, Checkpoint and Fortinet firewalls with identity updates. Take a look at the TechNotes on the support site.
Tim Cappalli | Aruba Security
