Linksys WUSB6100M cant connect to 2705A controller
Hi
i have an SSID that i cannot connect with this USB WiFi card
the SSID is WPA2 Ent with PEAP (user/password)
any known issues about it ?
thanks
Re: Linksys WUSB6100M cant connect to 2705A controller
Is there an error message on the radius server?
What options do you have enabled on that SSID?
Hi
I dont have radius
Its only user/password and after afew sec
I just get unable to connext this network .
I changed to another wifi card and it connrcted
Get Outlook for Android
What operating system is the client computer?
Win10
How is the controller configured?
What 802.11 options does the SSID have enabled?
Are you using termination on the controller in the 802.1x profile?
On the Windows client do you have "Validate Server Certificate" checked?
Hi
this is what u mean ?
Yes.  What about the answers to the other questions?
Hi
i think i found the problem . silly me
since i have two auth before i login , one is the user name and the second one was the MAC and when i entered the mac i wrote it in CAPITAL :(
now its connected
thanks for the support
