Load Balancing Inactive
Hi guys,
I have a customer who has been modifying the configuration he was left with without applying any change control.
Having decided he was getting poor load balancing he set the limit per AP of 12 clients. As a result his APs service up to 12 and clients will not associate to another AP until the nearest one is "full".
By setting his client limit to 12 did the customer disable normal load balancing?
When looking at AP details screen, see below, it states load balancing is "inactive" - has he inadvertantly switched it off when setting his client limit?
Cheers guys!
Re: Load Balancing Inactive
Do you have spectrum load balancing enabled under the
802.11a radio profile ?
If you find the post helpful please Kudo the post
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Please see this : http://community.arubanetworks.com/t5/Wireless-and-RF/AP-Load-Balancing-vs-Spectrum-Load-Balancing/td-p/3640
Thank you
Victor Fabian
