Load Balancing configuration for Aruba OS 3.4.0
Hi I has been trying to fund the configuration in the controller under GUI /CLI  and also I went to check under the User guide without luck, could you please help me out with this to configure it, Im experiencing issues with the users that are over using only specific APs I need to balance the users between APs.
Retired Employee
Re: Load Balancing configuration for Aruba OS 3.4.0
Hi my buddy,
This option isnot available on version 3.4, it exist maybe on version 3.3.x but not in 3.4.x.
Does it dissapear from version 3.4 as load balance and converted to spectrum load balancing ?
Both the local probe response and the load balancing in the RF optimization profile should be available.  Where are you looking?
Hummm maybe Im on a local controller and thats why I cant find the option, but I'm almost sure that I'm looking in the right place as the answer 276 indicates, let me check it again and if I can't get there I will post a screenshoot of the menu where I'm looking.
Thank you
