Frequent Contributor I
Local AP using 802.1x for uplink to local switch
Is there a way to install a certificate on an AP105 to use 802.1x authentication to local switch. We are using 802.1x to allow devices onto the network and would like to use the same method for all our local APs rather than something like Cisco port security. Haven't found any documentation that states it can be done and how.
Tony Marques
Re: Local AP using 802.1x for uplink to local switch
Only PEAP is supported today.
Sent from Nine<>
Tim Cappalli | Aruba Security
Are you aware of any efforts from Aruba to support AP EAP-TLS with certificates for it's uplink port?
None that we are aware of.  If you would like to see this, please post in the Ideas Portal here:  https://arubanetworkskb.secure.force.com/cp/ideas/ideaList.apexp
Colin Joseph
Aruba Customer Engineering
Thank you, however when I try to click on the link you provided, I recieve a SAML SSO error..
Okay.  Please PM me your customer details and I will file it for you.
Colin Joseph
 Colin,
I was able to post the idea on Jim's behalf. Thanks for the update.
Tony Marques
