Contributor II
Local controller administration settings
Good afternoon,
I am looking to change a local controller management setting from its existing authentication server group to a radius server group, however when I log in with root privileges (local account) the Server Group is greyed out and i cannot change it?
What am i missing?
Cheers
Dave
Re: Local controller administration settings
That is a global setting that must be changed on the master controller.
Contributor II
Thanks for the reply, I had made the change and tested on the master, but not saved, as soon as you said that, i clicked save and like replication magic it was there!
Cheers
Dave
