Logging client match reasons
I'm parsing my aruba logs and I see many client match events like:
Deauth to sta: 14:dd:a9:a8:8d:e1: Ageout AP 192.168.244-24:de:c6:13:64:80-EWFMA-Atrium Client Match
Is there a way to increase the logging verbosity of client match so that it will also log the *reason* for the client match event?
As far as I know there are three reasons a client can be moved:
sticky client
load-balancing the AP
It would be really helpful to be able to syslog the reasons for an event so I can then coalate them and get a better idea of what is happening in various physical locations.
