Logging to Barracuda Web Filter - Not getting IP address
Trying to configure Syslog from the Aruba Controller to a Barracuda Web Filter. We need to be able to send the username and IP address on successful authentications in order for the web filter to receive a login event, and update the username/IP in it's active sessions. We are getting successful authentications in the logs for the controller, but the IP address is always showing as 0.0.0.0. I assume this is because the log is generated upon authentication success/failure and not after DHCP takes place. Is there any way to generate a log that has Username=*username* and IP=*ip address* in that format. I was able to have it show "ipv4=*ip address*" by using the security category instead of user, but it doesn't accept that format.
Thanks.
Michael Haring
Architecture and Implementation Consultant
Optiv Security Inc.
Re: Logging to Barracuda Web Filter - Not getting IP address
Can the barracuda use the accounting information from the controller instead of using logging
Get Outlook for iOS
Thank you
Victor Fabian
Lead Mobility Architect @WEI
I'm not really familiar with the Barracuda, so I'm not sure, but we did work with Barracuda support yesterday and they made no mention, only syslog. Their documentation for Ruckus, Aerohive, and another WLAN was all syslog configurations also. Of course they didnt have an Aruba guide, but states it's supported.
Michael Haring
Optiv Security Inc.
