Lost Controller Management
Hi. I have an Aruba Controller 3200XM with 6.3.1.9 version. After adding the first PEFNG license I lost SSH and Web management. The only way to manage the Controller is thru console cable. Does anyone have any advice to fix it
Aruba
Re: Lost Controller Management
Make sure the port that is connected to your network is trusted.
For example:
show interface gigabitethernet 0/1
Look for This port is TRUSTED near the bottom
AMFX | ACCX | ACDX | ACMX
Aruba
If it is not marked as trusted; run the following for the appropriate port:
config t
interface gigabitethernet 0/1  (or appropriate port or port-channel for your connection)
trusted
wr mem
Thanks Clembo. After marking the port as trusted the management of the controller got back
