Occasional Contributor I
Lot of ping lost between 3 Aruba controllers and VDX directly connected.
  We have 3 Arubas Controllers plugged into 2 differents VDX routers.  If I enter in SSH session in any controller, and I ping the VDX interface (where the controller is plugged), we lost a lot of ping.  But if I ping anything other than the VDX interface, all is good.  It's the same problem for all our 3 controllers.  If we ping the controller from the VDX, all is ok.
We have:
2 controllers Aruba7210, v6.5.4.5
1 controller Aruba7220, v6.5.4.5
Anyone have an idea?
Thank you!
