Trusted Contributor I
Low EIRP on 11a radios after 6.2 upgrade
I recently upgraded to 6.2 and RSSI has been significantly lower for my daily laptop.  After looking into it, I found that the AP I usually associate to is running at a much lower EIRP than usual.  I started checking into other APs and found a downward trend in EIRP for most APs.  On 6.1, most APs were running around 18 - 21.5, but now the average is 12 - 15. My 11a ARM profiles are set to defaults, min/max EIRP are used. These settings were not modified after the upgrade.
I'm not confident that it's a 6.2 issue, but that's the last significant change that been made.  Anyone notice similar behavior on 6.2?
If a reply adequately addresses your issue, please click on the "Accept as Solution" and "Give Kudos" button so this information can benefit other users.
Re: Low EIRP on 11a radios after 6.2 upgrade
What AOS version are you using ? and APs ?
Thank you
Victor Fabian
Lead Mobility Architect @WEI
6.2.1.3 & AP105.
In areas where I have more APs I'm seeing this downward trend.  In areas that contain APs that are less dense, they're running at a much higher EIRP.  I'm going through RF history right now to see if I can spot any trends.
In 6.2 they are added some ARM scanning enhancements for APs with no clients associated so will allow the ARM to calculate it power/channel adjusments much better.
Also what are you using 20 or 40 Mhz channels ?
Thank you
Victor Fabian
Arm history should tell you why.
If you are using airwave the rf health report will tell you what access points have
the most power/channel changes.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
I'm using 20MHz channels.
It looks like a possible co-channel interference issue.  I'm seeing several APs sharing the same channel on the same floor.  I have client aware enabled and the noise threshold is set to default.  Maybe I'm not giving the APs any opportunity to change channels as a result of these settings.
If you want to be super-conservative, you can turn of client-aware at night.
Good call.  Will do that tonight.
Disabled client aware last night.  Came back this morning and re-enabled.  Channel reuse is a little bit better, but half of the APs are still operating at 9dBm.  Going to open up a TAC case.
