Trusted Contributor I
Low Goodput
This morning I have an unusually high amount of APs reporting low goodput on 5GHz.   These APs shows "0 - 6 Mbps" for more than 90% of the traffic TO the client.  Frame rates FROM the client are just fine, mostly 108+ Mbps.  Only a few APs' noise floor is below -85, channel utilization is very low, and there aren't a high amount of frame drops to the client.  Any suggestions on troubleshooting low frame rates to the client?
If a reply adequately addresses your issue, please click on the "Accept as Solution" and "Give Kudos" button so this information can benefit other users.
