Occasional Contributor I
Low Memory
What is the minimum memory required on the controller to operate without any issues ?
i have the log file and i don't know if that free memory is sufficient or not .. and if it will cause any issue ?
Re: Low Memory
Please refer Advisory
"Aruba 600 Series Branch Office Controller Out-of-Memory Support Advisory - SA-20160621 - Tuesday, June 21, 2016"
http://support.arubanetworks.com/Announcements/tabid/139/Default.aspx
Which talks about the Out of memory issue on Aruba 600 series controller.
Note: You should login to support site to view the Advisory.
Re: Low Memory
Thank you so much
Re: Low Memory
My pleasure!
