Occasional Contributor I
Lync 2013 optimization settings for Wi-Fi
Please can someone share the Lync 2013 optimization settings for Wi-Fi, the servers and APs are located in two different countries.
Re: Lync 2013 optimization settings for Wi-Fi
Please work with your Aruba SE. It requires some discussion.
Tim Cappalli | Aruba Security
Aruba
I agree with Tim; please try and engage your local Aruba SE or Reseller for a larger design discussion that is specific to your environment/deployment.  In the meantime, the Lync over Aruba Wi-Fi VRD would be a good start:
http://community.arubanetworks.com/t5/Validated-Reference-Design/Lync-Over-Aruba-WiFi/ta-p/199813
AMFX | ACCX | ACDX | ACMX
