Lync SDN API and split-tunnel
I've just gone over the excellent VRD for Lync integration and I see that the SDN API method is supported on a split-tunnel ssid,
I'm looking for a configuration example for the spli-tunnel, specifically the ACLs needed and what traffic needs to go into the tunnel to controller for it to work effectively.
I have a customer who wants to change everything to be bridge mode and I fear that any gain in performance from doing that (wan acceleration) would becoming meaningless if Lync performance was bad.  I'm trying to come up with a reasonable alternative and split-tunnel seems the way forward.
ACCP, ACCX #817, ACMP, ACMX #294
