Frequent Contributor I
M3 module capacity
What is maximum number of tunnels on the M3 module?
Re: M3 module capacity
Hi Mike,
Thanks for the link, I just want to be sure in ordre to scale my controllers.Is it 4096?
That's what it's looking like, Mario, if you're referring to IPSec tunnels
I am refering to GRE tunnels.
GRE tunnels for other controllers or routers or for APs?
GRE tunnels for Wired APs, Campus APs, Remote APs and Tunneled ports.
Hi Mike,
A campus AP uses one tunnel per SSID per radio. A S3500 wired AP may use one tunnel per port.
How can I make sure that I am not exceeding my M3 controller capacity?
Well, the M3 can do 8192 BSSID's with either 512 campus APs or 1024 RAPs.  You can do a combo of campus APs and RAPs, but you have to watch the ratio.  Hopefully the BSSID number will give you a better idea of the capacity.
