Contributor II
MAC Authentication on Wireless users issue
In our environment, we have a Master-Local controllers running version 6.5.1.6.
I have configured MAC authentication on a specific vap-profile with security type WPA2-PSK. Also, as you can see in the attachments I did exactly the same setup as mention in the below link
but all users are able to connect to this SSID even if their MAC addresses are not added to the internal DB.
http://community.arubanetworks.com/t5/Controller-Based-WLANs/How-do-I-configure-MAC-based-authentication-on-Aruba/ta-p/182430
Please advice,
Thank you
ACMP 6.4 certified
Re: MAC Authentication on Wireless users issue
What is your initial role ?
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Contributor II
Hello Victor,
This is the initial role:
aaa profile "Nestle-aaa-prof"
        initial-role "Authenticated-Role-Nestle"
        mac-default-role "Authenticated-Role-Nestle"
       authentication-dot1x "default-psk"
       dot1x-default-role "Authenticated-Role-Nestle"
Create a role that denies all traffic and assign it to the initial role
Thank you
Victor Fabian
Contributor II
Hi Victor,
Thank you, today I've did what you said and it works properly.
Regards
