Regular Contributor II
MAC and PSK needed on same SSID
We were need to have our SSID with MAC and PSK. We want to have it where you need to pass both MAC and PSK on the same SSID. Can this be done and if so how can this be done?
Re: MAC and PSK needed on same SSID
Do you have ClearPass?
Is this controller or Instant?
Tim Cappalli | Aruba Security
We will be installing ClearPass very soon. Currently it is controller based.
Trusted Contributor I
should be doable as long as you want both to succeed. just configure mac auth profile and server group (for now local, later on might be clearpass) on the AAA profile which has the PSK setting configured.
mac lists are of course not the greatest thing to have and maintain, but that is up to you to accept or not.
