MESH AP deployment with ALE
As per subject is MESH AP deployment with ALE possible?
using 5hz for Meshing and 2.4ghz for ALE
will there be any accuracy issue for the ALE?
Re: MESH AP deployment with ALE
The ALE functionality should work the same regardless (assuming you are doing all the location tracking via 2.4Ghz). However, if these are outdoors, location accuracy likely goes down simply because the algorithm is built for indoors and triangulation, and once you get outdoors, with less RF attenuation, less reflectivity, and higher FSPL likely results in larger location variations and lower accuracy.
Jerrod Howard
