MESH Configuration
Hi Community:
I've configured a mesh network with Aruba Controller 7030.
My question is: How can I configured a mesh network among three Access Points.?
The first one should be Mesh Portal, because it is connected to the switch, but what about the others access points, because these one just has AC cables.
Any Idea?
Thanks in advance.
Re: MESH Configuration
They should be provisioned as mesh points, if they will not be connected to the network via ethernet.  Provision them and reboot.
Colin Joseph
Aruba Customer Engineering
Thank you so much.
It's working now.
