MESH Failover from Switch link failure
Hello Everyone,
Does someone know or has implemented the following situation?
Switch X is connected to AP(A) and AP(B). Both APs can "see" each other also.
Is it possible to AUTOMATE a Switch-AP link failure with MESH connection between APs?
Re: MESH Failover from Switch link failure
Instant could work that way, but not AOS currently.
Jerrod Howard
