MESH between AP 275
Dear All,
I need your advices , i have configured and test in lab a Mesh link between 2 AP 275 in order to deploy it in POC , in the lab all works correctly (in a short distance).
After the deployment , the one AP get instablle , and the other get off.
the distance between mesh portal and mesh point is between 50 and 60 , Meters, with a clear line of site , the used version is 6.4.3.5 .
could you please advice me please.
Raouf
Raouf CHAHBOUNE
ICT Network & Security Engineer
CCNP R/S | CCNA Security | ACMP|ACCP|ACDX
[If my post is helpful please give kudos, or mark as solved if it answers your post.]
Re: MESH between AP 275
Are these controller-based access points, or IAPs?
Sometimes it takes awhile to restablish the mesh link at that distance (10 minutes).  How long did you wait?  Did you console into the far end mesh AP to take a look?
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
it's an Controlleur Based AP .
the Access point are still installed  .
Raouf
Raouf CHAHBOUNE
have you analyzed the output of
show ap mesh tech-support ap-name <ap-name> <filename>
Most of the times it gives you valuable information.
You can share it if you want.
For the Mesh point, you should type:
show ap allowed-channels country-code <your country code> ap-type AP-275
Make sure that your mesh portal is on one of those allowed outdoor channels.  The mesh point will only scan on outdoor channels.  The only other option is to get a console cable and take a look at the AP275 on the far side and what is wrong.
hi ,
i found this , and it may be the cause of my probleme.
Raouf CHAHBOUNE
