Super Contributor I
MESH
Hi Team,
Good morning, the MESH scheme is possible with 205 AP?
If using MESH with controller and AP 205, as is the scheme?
  •   Should have a MESH PORTAL?
  •   MESH AP to communicate with a particular band?
Re: MESH
2014-06-11 10_21_02-www.arubanetworks.com_pdf_products_DS_AP200Series.pdf.png
 http://www.arubanetworks.com/techdocs/ArubaOS_60/UserGuide/Mesh.php
It uses the 802.11a band to form a mesh connection
Thank you
Victor Fabian
Lead Mobility Engineer @ Integration Partners
Re: MESH
Please note that mesh support within the 11ac APs is expected around the Sept/Oct time frame.
Jerrod Howard
Re: MESH
Thanks jhoward , I wasn't aware of that....good to know.
Thank you
Victor Fabian
Super Contributor I
Re: MESH
Hi Team,
This support will be an update ARUBAOS?
Re: MESH
It will be an update to ArubaOS as well as Aruba Instant, both should occur around the same period of time.
Jerrod Howard
Super Contributor I
Re: MESH
It will be possible to use the band until 2.4 is released to the AP 205 AC?
Re: MESH
2014-06-11 10_54_02-www.arubanetworks.com_pdf_products_DS_AP200Series.pdf.png
Thank you
Victor Fabian
Super Contributor I
Re: MESH
In the configuration de Mesh. The Mesh Portal, also allows connection to provide users with WLAN 802.11b / g?
Thanks!!
Re: MESH
Correct, the radios will still broadcast the SSIDs like any normal AP.
Jerrod Howard
