ryh
Contributor II
MM - Mobility Master and MD controller config moves
I'm working on migrating from 6.x to 8.x two 7220 controllers as managed nodes, using MM.  Using the migration tool, we successfully migrated them with the following layout:
/md:
/md/Bldg_A/A-controller/00:11:22:33:44:55
/md/Bldg_B/B-controller/88:88:88:88:88:88
The B-controller was migrated first, as it was not in production and had an old configuration file.  Then we migrated the A-controller.  Now we want to make the B-controller config use what the A-controller is/has been configured for.
Is there a way to quickly move the configuration from the A-controller to its node parent?  I've been trying to add the profiles to the parent but the GUI and CLI complains that a child already has that profile configured.
Re: MM - Mobility Master and MD controller config moves
What version are you running ?
Thank you
Victor Fabian
Lead Mobility Architect @WEI
ryh
Contributor II
MM - 8.1.0.4
7220 - 8.1.0.4_61790
The functionally to move nodes between folders was introduced in AOS 8.2 but since you are running 8.1 you will need to reset the controller to default factory and then add it under the building A folder
Get Outlook for iOS
Thank you
Victor Fabian
